Hinkley Lighting, 3145-Led, Ceiling Fixtures, Congress, Indoor Lighting, Semi-Flush,Oil Rubbed Bronze Single Light Led Semi-Flush Ceiling Fixture With Teardrop Shade From The Congress Collection Features: Etched Opal Glass Teardrop Shade - Etched Glass Shades Offer Creative Patterns And Designs - Made Of Steel - Designed To Cast A Soft Ambient Light Over A Wide Area - Can Be Mounted Facing Upwards Only - Energy Efficient - Suitable For Dry Locations - Lamping Technology: Led - Light Emitting Diode: Highly Efficient Diodes Produce Little Heat And Have An Extremely Long Lifespan. - Specifications: Bulb Included: Yes - Bulb Type: Led - Canopy Diameter: 7 - Height: 12 (Measured From Ceiling To Bottom Most Point Of Fixture) - Led: Yes - Material: Steel - Number Of Bulbs: 1 - Product Weight: 5 Lbs - Shade Height: 7.5 - Shade Width: 8.75 - Sloped Ceiling Compatible: No - Title 24: No - Ul Rating: Dry Location - Voltage: 120V - Wattage: 15 - Watts Per Bulb: 15 - Width: 6 (Measured From Furthest Point Left To Furthest Point Right On Fixture) - Compliance: Ul Listed - Indicates Whether A Product Meets Standards And Compliance Guidelines Set By Underwriters Laboratories. This Listing Determines What Types Of Rooms Or Environments A Product Can Be Used In Safely. - About Hinkley Lighting:Since 1922, Hinkley Lighting Has Been Driven By A Passion To Blend Design And Function In Creating Quality Products That Enhance Your Life. Hinkley Is Continually Recommended By Interior And Exterior Designers, And Is Available To You Through Premier Lighting Showrooms Across The Country. They Pride Themselves In Delivering Superior Customer Service That Is Second To None. They Know That You Have Goals When It Comes To Your Home's Decor, And They Care About Helping You Achieve The Final Outcome You Are Looking For In Every Aspect.
Store | Price |
Build.com | [show price] |
Stop buying oher cull. This is the one and true quality Hinkley Lighting 3145-LED 1 Light LED Semi-Flush Ceiling Fixture with Teardrop S. That you might have at best price in the whole internet. Lets buy it from this Build.com and you will see the difference.
